Using BCM from another Car?
Going to swap BCM from another Camaro Into mine Cars and accessories same same. anything else I need from donor Car or problems I will encounter.
I swapped my BCM a few years ago. I had already done the VATs bypass previous to that.... and yes, you'll have to match it.
I can tell ya what I did and it was a pain ... I didn't have the resistance value for my replacement BCM so I used a potentiometer and tested each value (there are 15). Unfortunately every time that I changed the resistance, I had to unplug the battery.... I guess to reset the BCM.
