1994 Camaro ABS Delete
I was working on deleting the ABS on my 94 LS1 swap project today and went to flare a double flare on the large rear brake line. Tube kept slipping through the clamp and after taking some measurements I discovered it is actually a metric 6mm line instead of 1/4" (6.35mm). So my flare tool wouldn't hold it in the 1/4" slot of the clamp. Everything I had read stated the 4th gens had 1/4" rear brake line, how did everyone else do there ABS delete if they were using a English flare tool?
