Bump stops
So my question is : I have a 99 SS with the SLP sport suspension package level 2 ( Bilstein) and from what I have narrowed down is that when I'm hard on the throttle the car squats and hits the stops has anyone removed the stops ? Will it hit the rear end ? It squats pretty hard because of the increased HP it's far from stock it might seem like a dumb question but before I took them off I was wondering if anyone has ever removed or cut them ? Any information would be greatly appreciated
Either way if you remove the bumpstops that give the torque arm a chance to punch a hole in your floor boards, this has happened before on here.
Your wheels and tires can also come in contact with the body of the car if they are any wider than stock too.
With your car being over 18 years old the poor quality foam bumpstops are going to be cracked and falling apart. You can probably grab them with your hand and crumble them, unfortunately that is normal for the stock later 4th gen bumpstops at this age. 3rd gens (and early 4th gens I think) got real rubber bumps stops and they actually last a long time.
Something else you can do that will actually help your ride quality a little it to remove the spacer between the bumpstop and the mount on the car. You will gain a little suspension travel with no down side.
