2001 camaro 3800 v6
2001 camaro 3800 v6
Crank but no spark. Changed crank position sensor. Still no spark. Test ignition control module. It tested good. I was told engine control module or computer was only other part that controls spark. Is that true? Changing parts is expensive if that doesn't solve problems. Please help.
The nice thing about these factory service manuals is that they are put together by the engineers who designed and built these cars, so they know how all the systems interact and what steps you should do (in the proper order) to track down the root of your problem. Even if you were to give up and take it to a mechanic, they would rely on service manuals like these to diagnose and repair your car. Good luck!
