93' Sreet Car Build
#61
You're going to have the quietest Camaro in the country. Is that going to add a bunch of weight?
#62
I sure hope so, I really want it to be quiet/comfortable like a modern vehicle. I think the extra weight is worth it, I would guess its under 100lbs, so not much in the grand scheme of things. This will just be a street cruiser, so Im not concerned with shaving every ounce at this point.
#64
I installed the 6 channel RCA cable and then put the carpet back in. I still need to clean the carpet, but needed to put it back in the car due to space.
#65
RCA's in place, now I need the amp so I can get everything hooked up.
Picked up the replacement dash assembly, cant wait to get this thing back in one piece.
#72
Still working on the dash, installed the ducts on the drivers side, set the gauges in place to verify the LED backlighting works, installed the HVAC controls (also LED backlit) and the glovebox w/LED light.
#74
Also working on the center console, adding a voltmeter/dual USB charger and line level control for the sub channel.
#79
383z, I will let you know, just doing the hatch area on my last car was a huge difference in road noise... Im really hoping that this one is better for all of the work. I really hate road noise, rattles, vibrations, etc. I appreciate it, Im really trying to build a nice all around car.
