1995 camaro headlights (aftermarket)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
found these on a truck website. same dimensions as the stock buckets. just curious if anyone has used these or know someone with something similar.
https://www.raneystruckparts.com/4-x...UaAiY7EALw_wcB
Ungrounded Moderator
No, those will NOT fit. They are the correct size (4 x 6) for the LT1 Firebird, but the Camaro takes H4351 and H4352 lamps which are 5.75 x 2.48. There are conversion kits which consist of housings that accept replaceable bulbs which can be LED. There are also the same sort of "sealed beam" LED replacements available in the correct size. Just Google "H4351 LED" and "H4352" LED" to find some.
