Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Old 05-13-2016, 04:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
LS1 SS vs LS1 Z28
Old 01-16-2008, 07:33 AM
  #41
Nick_Rapitis's Avatar
thanks for the info
Old 01-16-2008, 01:38 PM
  #42
CCCustoms's Avatar
Originally Posted by RPM WS6
You will not find proof, because it is not true. HERE is the truth:
Injector size is based on year, not model. An LS1, is an LS1. No difference from Z28 to SS to Trans Am to Formula, as stated in the quote above.
None of the F-bodies come with an actual 3" exhaust unless you ordered your SS with the SLP dual/dual as a Y2Y option. Or if you have a Firehawk (they came standard with the dual/dual). A base SS has the same I-pipe size as the Z28, only difference is the tailpipe size (2.5" for the SS, 2.25" for the Z28).
Shocks are the same stock, unless you have a 1LE SS or an SS with Bilstein suspension from SLP (also an extra Y2Y option).
There is no difference with the intake. '98-'00 Z28s and SSs have an LS1 intake, and '01-'02 Z28s and SSs have an LS6 intake.
If you mean the difference in the air lid, there is ONLY a difference if the SS had the optional Blackwing lid through SLP (another Y2Y option). Otherwise, the SS and Z28 have the same air lid.
Thanks for the info RPM WS6 , I tell people on hear every week that they learn something new, know it is me learning something new, But if we new everything about i CARS we would not be on LS1tech and wear is the fun in that.... LOL.
Old 01-16-2008, 01:59 PM
  #43
BLACK2001SS's Avatar
The SS came standard with 2 3/4 I pipe just so you know because I did post 3 which thats not standard.
but the Z and the SS are 99% the same.
And a lid and a SSRA kit work wonders for this car.
Old 01-16-2008, 02:05 PM
  #44
streetassasin's Avatar
Z28's came with a LS1 SS's came with a LS1.5
Old 01-16-2008, 02:14 PM
  #45
WU8 code for 01 camaro The SS appearance Package includes a forced-air composite hood, SS badging, rear spoiler, low restriction/ dual-outlet exhaust with larger pipes, power steering cooler, High preformance ride and handling package and SS 17 inch rims whit eagle f-1's. thats what it says in the restor guide from GM.
Old 01-16-2008, 02:16 PM
  #46
well LS1.5 for 01 but in 02 it was a LS1.75.
Old 01-16-2008, 02:18 PM
  #47
All SS's got the LS1.5, it was the WS6's that got the LS1.75
learn your history man
Old 01-16-2008, 02:24 PM
  #48
My bad
Well it not like this is a topic that is talked about that often its hard to find all the info on it because GM is trying to keep it top secret.
Old 06-20-2008, 01:07 PM
  #49
LS1-NAVY's Avatar
Originally Posted by 35thZ28Man's_wife
Oh ok, I thought that there would be a code on the info, just got an 02 SS Vert, bought it from auction, just thought I would check all the specs, thanks!
does it have the blackwing air lid if it does then it has it if it has the baffels or w/e than its the stock lid
Old 06-20-2008, 03:29 PM
  #50
black2002SScamaro's Avatar
I've owned one of each, the difference isn't much. I always thought the engine should be different with a significant difference in power, like 60 hp, but there really is no difference.
Old 06-29-2008, 12:11 AM
  #51
yaco7usa's Avatar
I like the SS better then Z28 just for the way it looks
Old 07-19-2008, 08:55 AM
  #52
LEEEPPS74's Avatar
i had 1994 z28 and my cousin had the first ss that came out , i had a lid , catback , maf and programer, and i beat him like drinking water
Old 07-20-2008, 12:44 PM
  #53
S_carve's Avatar
yup that what mine says also so i really dont know who to believe here
i was pretty sure the SS suspension was different even if it was just swaybars and springs
maybe i need to slp with my VIN and ask them
Old 07-20-2008, 01:56 PM
  #54
lbls1's Avatar
Just to add (if it hasn't been mentioned yet)
Aside from the engine (there are no differences in the engine itself),
1. There are differences in the suspension bet. the Z28 and the 'SS (regardless of base and additional content). The 'SS got a bigger front sway bar, stiffer shocks and jounce spacers. You could have had your choice of optional suspension components in the 'SS with level 1 and 2 suspension set ups, where you could've received either lowered springs, a thicker front sway bar, and bushings for the panhard bar and lower control arms. The level 2 option would have given you the adjustable shocks.
2. There is a difference in the vin between the Z28 and 'SS. All 'SS cars (there may have been some exceptions during the last year and perhaps with some canadian models..not sure) were finished and given a serial number by SLP, regardless of content.
3. You had a choice of different catback exhaust set-ups with the 'SS, where as you did not have that option available for the Z28.
In all, IMO the differences between the SS and the Z28 won't really amount to a noticeable handicap in performance for the Z28, unless the car was ordered with all season radials; In that case, the speed for the non-z rated tires would've been limited to +-110 mph. As long as you have or are looking to buy a mint fcar with an ls1, then the motor and the car's condition is the most important thing.
Quick Reply: LS1 SS vs LS1 Z28
