emissions testing - LS1 engine in 92 Camaro?
hello i am new to this board and i have been doing some looking around and i have some questions i wanted to know if i could get help with. i am looking to try to drop an ls1 eng with a 4l60e tranny in a 92 5.7l camaro. but my prob is before i start to do this would this be streel legal and pass emissions testing?
thanks for any help i can get
ps i did search but did not find anything that looked like it answered my question
Deranged Rat Fink
1 Post
Sure you can , even in California , I believe. You won't have a problem with putting a newer engine in a older car. Perfectly legal. It's when you put an older engine in a newer car that might cause you problems. Emmissions laws vary from state to state and even within the state from county to county. Here in TN, if you live in a major metropolitan area or a surrounding county , you have to go through testing . In rural counties , you don't . They are looking at changing these laws but that's the way it is for now.
thanks i was not sure if it would pass i was looking at www.speartech.com but they said something about not pass emissions testing
im pretty sure as long as you got all the smog equipment (egr and air valves) they wouldn't even notice. you could check with a referee in your state to make sure or just check local law. a lot of guys are so dumb at smog though, they wouldn't even notice as long as had the egr and air valves
yea well i am in pa right now and i know enough shops that if you lip them a 50 they will pass it running open headers but i am moving to delaware and the state dmv does the testing
I've always heard if you replace an engine in a car with a newer engine, the vehicle will be held to the emissions standards of that engine. Example: you swap out the 5.7 in your 92 with a LS1 from a 2000 F-bod... you now must meet the 2000 f-bods standards. That's mearly something I've heard mind you. I have no idea how they would be able to tell though unless you told them what you did. The emissions folks here would never notice- they just look for the pass/fail and make sure things like cats and mufflers are present.
