Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Difference between v6 vs Z28?
Old Nov 10, 2005 | 05:02 PM
camarOH !'s Avatar
Default Difference between v6 vs Z28?
I'm looking to buy a camaro and build a 383 or 396 for, or something along those lines...
so besides the engine and tranny, whats the difference?
like exhaust, suspension...everything else.....
Old Nov 10, 2005 | 05:31 PM
ROCNDAV's Avatar
If you're talking about a 98-02 then not that much. 93-97 will have more stuff thats different (ask me, I know).
The front springs are different, but I think some people use them when using tubular K member/a Arms, headers and fiberglass hoods. The A/C pump will be different, but you maybe be able to use your existing lines and just =swap out the pumps. I'm not sure about the 3.8 K member, but I'm sure that it is different from the LS1, as possibly the motor mounts.
THe PCM and PCM harness would be different.
Old Nov 10, 2005 | 06:45 PM
davered00ss's Avatar
Moderator
PCM and wiring harness are the big thing. Always better to start with a car that was a v8 to begin with.
Old Nov 10, 2005 | 11:39 PM
bbfirebird's Avatar
the steering ratio is quicker on the V8s than on the V6s. not sure what the numbers were, i think it was somewhere around 14:1 for the V8s and 16:1 for the V6s.
