The official swap thread of my Camaro.56k ,RUN!
#222
Deranged Rat Fink
1 Post
Okay , today , I installed the 4th gen gas tank. I wanted to keep use of the charcoal cannister and evap solenoid so I drilled out the rivets that held the fuel pump /fuel level sender harness , made a template and cut a larger hole . Afterwards , touched up the screw holes and bare metal of the cut with POR-15 then installed new harness. Here's the result:
![](https://img171.imageshack.us/img171/1678/swappics001if2.jpg)
There are 3 seperate plug in this connector you only use two. 3rd is for ABS which I won't be using.
Then I installed the 4th gen tank , it fit perfect . You will need to trim the rubber filler neck down a bit as it is too long.
![](https://img296.imageshack.us/img296/9000/swappics005tj7.jpg)
And finally installed the aluminum 4th gen driveshaft , also fit perfect .
![](https://img187.imageshack.us/img187/9145/swappics002vd8.jpg)
#223
i wish i knew enough about cars to work on 1/3 of the stuff you know how to do lol.
and what do you do job wise to afford all this. win lotteries?
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
#224
Camaro 3.9.5
Higher gen than 3rd, not a 4th though, yet more tech slapped onto it than the 4th gen so it gets the additional .5 !
I am debating if it gets the beta moniker. Maybe it gets it until you take it out to have it dyno tuned...
#225
Deranged Rat Fink
1 Post
and what do you do job wise to afford all this. win lotteries?![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
#226
Originally Posted by badjuju342
If you're mechanically inclined at at all , you CAN do this swap after a little research.
#230
I've got to install brake lines, fuel lines , wire the car, exhaust and finish the cooling &A/C , so we are getting fairly close.
Can we get a read-out on your suspension mods? Like sway-bar diameters, etc?
#232
Deranged Rat Fink
1 Post
#236
Look at most of the Spohn catalog for 3rd gens, Eibach Pro kit , BMR adjustable panhard and that's my suspension . I also have a Hawk's tubular K-member.
How's the tubular K-member? I haven't heard anything but problems with cracking welds from the drag racers to a sloppy front-end by the street/track drivers.
That was before they upgraded the K-members to address the problem, I noticed that a lot of them also list it as semi-streetable/race.
#237
Deranged Rat Fink
1 Post
It bolted on pretty solid and seems fairly sturdy to me. I bought on of the first ones. I haven't had a chance to test it because we're still at the build point. I was told by other people using the stock A-arms are really difficult to bolt on to the K member . The Spohn tubular A-arms fit really good and they are vastly more stout than the stockers.
#238
I heard good stuff about the A-Arms being tough and nicely made.
I just couldn't afford them at the time!
