Oil pressure problem
![Red face](https://ls1tech.com/forums/images/icons/icon11.gif)
I just put a fully reconditioned stock LT1 in my 1995 Z28. When the motor is cold it runs great, however when the engine get to operating temp the motor misses and will not hold oil pressure at Idle.
Has anybody here had this problem?
The motor has a new melling pump and the pick up clearence was carefully messured to the manual specifications and tack welded in place (in the last motor-I messed up the motor becuase the pick-up bent out of place) so I was extra carefull in setting up the new engine oil pump.
Thanks in advance
Thanks in advance
