whats good for a carburated 350?
Well guys im new in this but just wanted to know what will be good for my 82 camaro it has a 350 chevy small block carburated engine? thanks.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Agreed with Nate's statement.
You need to figure out:
Plans for the car (be realize here, not a dreamer and end up way short of your goal)
Budget (see limitation statement above and apply here as well)
Post back ip and you'll see more answers.
Derek
Derek
Originally Posted by black84z28
vortec heads
extreme energy 274h cam
vortec airgap inake manifold
crane race gold 1.6 rockers
holley 4779 dp
and run mid 12s
holley 4779 dp
and run mid 12s
we don't even know about the rest of the car......
What's your idea of "good" bro? How'd the 350 get in it? Do you want it to just run ok or you want ideas on how to make it a bruiser? Not trying to give you a hard time, just want some specifics on what you're asking.
7 Second Club
1 Post
vortec heads
holley 4779 dp
and run mid 12s
holley 4779 dp
and run mid 12s
If you figure the car weighs 3500-3700 lbs with you aboard, you'll likely need around 400 hp (or about 320 at the wheels) to get your mid 12s.
Don't forget, these are all guesstimations, but should give you a general direction. Good luck!
Derek
thanks for the advice..
Well i know it was removed from a chevy truck and it seems to be a very strong engine.. Sounds great but how much power ya think I can get out of it because I don't want to spend alot of money for nothing. Instead just place another engine but hopefully the engine that I have right now can be good enough for me.
looking for mid 11 or 12 sec at the 1/4 mile...
check out my engine can barely see hopefully ya have an idea on how it looks..
Originally Posted by Nate81Camaro
and thats guaranteed to run mid 12's????
http://www.carcraft.com/techarticles/81998/index.html
granted...if someone was building a drag car i'd sure hope they would make sure everything else was up to par with what the motor needed to work correctly
Originally Posted by Villain281H
If this is what you already have, not bad for starters. I'd make sure the trans is built well with at least a 2800 stall loose 11 inch convertor or more, a reliable rear end with good shocks, a posi/limited slip rear with 3.42 gears if not more, and a flee-flowing exhaust with 1-5/8 inch headers. If the ignition is stock I'd upgrade that to your choice, but I'd suggest MSD from my experience.
Derek
Derek
this is what i am thinking about going after for a cheap build to get my car some more power but i am sorta stuck in a rut on what i want...but who could argue with a very streeable 380rwhp+ car
That makes more sense now...
