AC hose routing question,,
I have a 95 Caprice with a lsx motor installed. Car runs great!! 13.2 @104 ,,4300lbs . Gotta love these motors..
The problem that I am having is the AC unit = 2002Fbody. I am not sure the guy who fabbed up the hose routing did it correct. I can not seem to get the system to cool. By chance would anyone know or direct me to some pics that show the way the system should be connected. On the back of the compressor it has a tube that the upper line (more towards top of motor) then a lower line. The way it is currently connected the upper Line (upper tube) from compressor goes to the receiver dryer, the lower goes to the condensor. I just need to make sure that the routing is correct and not backwards. I am guessing it is OK as the Lo-Pres, side reads good and hI press. side seems to measure OK. I may just have a bad compressor but wanted to attempt to eliminate the obvious. Any help greatly appreciated.
THanks Roger,,
THanks Roger,,
Nice looking car
According to the Helms Manual, at that temp, you should be more like 40-52psi on the low and 210-310 on the high
It seems like the compressor is OK, but I am no expert. If you didn't install the system yourself, I would vacuum down the system and clean it out and add 24ozs of R134.
Originally Posted by SilverSierra
Nice looking car
Roger
