Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
b4c question...
Old Mar 4, 2007 | 03:55 PM
b4ckid02's Avatar
Default b4c question...
i have a 2002 b4c camaro from the Flordia Highway patrol. I no the b4c camaro is is almost the same as z28, but i was wonder what excactly is the diffrence between the z28 and the b4c...thank you
Old Mar 14, 2007 | 12:05 PM
b4c2002camaro's Avatar
Default Hard to Verify
I bought a FHP B4C in January and have done a lot of research on how the 2002 B4C compares to the 2002 Z28 (other years may be different). As best I can determine so far they are the same except for the ticket light in the B4C. One post said the B4C had a more powerful alternator but that may not have been true for 2002. Mine has RPO K43 GENERATOR 102 AMP; I don't know what is standard on the Z28. The "Camaro White Book" says the 2002 has 1LE rear (lower) control arms but other posters have said this is not correct. Of course the 2002 B4C is a hardtop and has a GU5 3.23 rear end.
It would be nice if someone could verify what differences, if any, there actually are between the 2002 B4C and Z28.
My daytime running lights are disabled and yours are probably the same.
Here is a list of my RPO codes:
1FP87 CAMARO COUPE
AG1 ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AK5 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS
AR9 SEAT FRT BKT, DELUXE
AU3 LOCK CONTROL, SIDE DR, ELEC
A31 WINDOW, POWER OPERATED, ALL DOORS
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B4C SALES SPECIAL SERVICE POLICE PKG
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR
DL5 DECAL ROADSIDE SERVICE INFORMATION
EGW FLEET PROGRAM "DELAYED WARNING"
E2C ORDER TO DELIVERY EXPEDITE TO CUSTOMER
FE2 SUSPENSION SYSTEM RIDE, HANDLING
FE9 CERTIFICATION EMISSION, FEDERAL
FLT SALES PROCESSING OPTION
GU5 AXLE REAR 3.23 RATIO
G80 AXLE POSITRACTION LIMITED SLIP
IBP TRIM INTERIOR DESIGN (PB)
J65 BRAKE SYSTEM PWR, FRT & RR DISC
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUM, GM
MX0 MERCHANDISED TRANS AUTO PROVISIONS, O/D
M30 TRANSMISSION AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC
NF7 EMISSION SYSTEM FEDERAL, NLEV
NK3 STEERING WHEEL SPORT, SOFT RIM, SIMULATED LEATHER
N96 WHEEL 16 X 8, ALUMINUM CAST
QFZ TIRE ALL P245/50ZR16 BW R/PE ST TL AL3
R6D CONTROL SALES ITEM NO. 04
STE PLANT CODE ST THERESE, PQ, CANADA
T82 HEADLAMPS CONTROL AUTOMATIC ON-OFF
T96 LAMP FOG, FRT
UB3 CLUSTER INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UN0 RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK, ETR
UQ0 SPEAKER SYSTEM 4, DUAL FRT DR MTD, DUAL STD RGE QTR/SHELF
U73 ANTENNA FIXED , RADIO
VK3 LICENSE PLATE FRONT FRT MOUNTING PKG
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH
VQ2 FLEET PROGRAM DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE
V12 COOLING SYSTEM POWER STEERING, FLUID
V2G CREDIT FULL FUEL FILL
V73 VEHICLE STATEMENT USA/CANADA
1SP PACKAGE OPTION 14
1SZ DISCOUNT OPTION PACKAGE
41Q MOLDING COLOR BLACK
41U PRIMARY COLOR EXTERIOR, BLACK
6BS COMPONENT FRT LH COMPUTER SEL SUSP
7BS COMPONENT FRT RH COMPUTER SEL SUSP
8TJ COMPONENT RR LH COMPUTER SEL SUSP
9TJ COMPONENT RR RH COMPUTER SEL SUSP
92B TRIM COMBINATION CLOTH, MED DK PEWTER II/VERY DK PEWTER
92I INTERIOR TRIM MED PEWTER II/VERY DK PEWTER
BC/CC
U8555
Old Mar 17, 2007 | 11:28 AM
Surely somebody knows what the standard alternator is on a 2002 Z28.
Old Mar 17, 2007 | 05:10 PM
Sneakyws6's Avatar
On the tree
102 amp...
Old Mar 17, 2007 | 06:56 PM
LTSpeed's Avatar
I'm not sure, but I think 97 B4C's were the last to have the 140A alternator. It was a lot easier to replace than the LS1's too! (But that's about the only easy thing on the LT1!)
Old Mar 18, 2007 | 12:23 AM
Originally Posted by Sneakyws6
102 amp...
Thanks for the confirmation. It seems, then, that the 2002 B4C is identical to the 2002 Z28 except for the ticket light and the lack of badges (and possibly the lower control arms if the White Book is accurate).
Old Mar 21, 2007 | 03:00 PM
SCHP98ls1B4C's Avatar
i think there the same but my car runs strong as hell my 98 a4 runs down my buddys o2 ss a4
Old Mar 22, 2007 | 11:31 AM
So, let's start a rumor that all B4Cs are faster than SSs because the B4Cs got used to running fast catching speeding Mustangs.
Old Mar 22, 2007 | 11:40 AM
yesterday i was looking under my hood and my number 8 spark plug wire was barely in the coil no where near snapped in and i went 13.50 1st pass ever after i plugged the wire in my coil the car feels much faster with 140k miles
Old Mar 22, 2007 | 12:21 PM
thunderdan74's Avatar
No his point is that a 98 is quicker than a 02 which is just not true. There's no difference in the motors of same year LS1 powered SSs', Z28s, B4Cs, Trans Ams and Firehawks. There was something wrong with the 02.
Old Mar 22, 2007 | 07:46 PM
yeah right something wrong with his car i doubt it with 13,000 miles i only pull like a car on him my car is very capable of low 13 sec passes nothing wrong with his car or mine dont get hurt i didnt say im faster then all of the 02's *** no im not saying i have a freak just a well taken care of 98 ls1.
