Big Freakin Tires!!!!
ok i want to put the biggest tires on my 2002 ss will 315 35 17 with a 17x11 wheel fit and 275 40 17 fronts? if they do where can i get the c5z06 chrome wheels at??
you cant put those on z06 wheels.. the widest they make in a 17 is 9.5 allowing you to fit a 285.. if you get the 18x10.5 you can fit a 315/30/18... the 275/40/17s will fit the 17x9.5s perfect for the front.. btw a mod will prob move this to the wheel and tire section.
if you still want z06s go to tomzwheels.com
http://www.1010tires.com/TireSizeCalculator.asp
315's won't SAFELY fit on a 9.5 rim........but do what you want....your jsut gonna wear out the middle.
If your having that much trouble hooking up, I'd look into a couple suspension mods first
Stock Tire - 315/35R17 >Search Tires
Section Width: 12.40 in 315 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 10.5 - 12.5 in
Overall Diameter: 25.68 in 652.27 mm
Sidewall Height: 4.34 in 110.23 mm
Radius: 12.84 in 326.13 mm
Circumference: 80.67 in 2049.0 mm
Revs per Mile: 809.9
twas an assumption...why else would you want huge tires out back? Do you not like fuel economy? There is always looks I guess...I'd still rather have a skinnier tire and the suspension mods...get you down the track much faster. ie. less drag.
((((((Administrator))))))
>>>PLEASE READ @ 315's<<<
Originally Posted by Xsta Z 28
This will not be discussed. I will not tolerate that kind of post. If I see if posted it will be deleted no questions asked.
Read the tire manufacturers recommendations.
If you are foolish enough to try it fine . . .
If you find a tire shop ignorant enough to install them fine . . .
But encouraging others to recklessly experiment, NO. Do not PM me in regards to this, I will not reply. If you don't like my stance then complain to Brains or Nineball.
Sincerely,
The Tire ****
Sincerely,
The Tire ****
