PLEASE HELP it does not want to start when i want it to
NOT STARTING please help
PLEASE HELP it does not want to start when i want it to Hi guys,i have a BIG promlem with my SS its starting to play up, i bought it in feb last year and it was fine until jan 2007 then the problem started it does not start when i want it to i thought it was because it was in storage from October 2006 till may 2007 but it was not that so i bought a new optima battry and a C-TEK trickle charger it was not that either i dont no what it is. PLEASE HELP
i have the same prob with my TA. wont start sometimes and i know its not a dead battery, no clicking, nothing. the everythign gets power when i turn the key to on and when i start everythign tuns off and nothign. i have to shift through the gears hard to get it to start. it olny does it when its ben on fo a botu 5 minutes before. cold starts are fine and after long drives it fine. if you figure anyhting out please tell me
manual, my friend had kinda the similar problem with his jetta(auto). it wouldnt come out of park so he got it in and they said the switch that tells the cpu (or something) that the brake is down went bad. could there be a simmilar prob with mine?
Hi krink85, I was reading on ls1.com that somone has the same problem somone else replied and they said to replace the starter & ignition relays in the fuse box under the hood the guy with the problem tryed it and so far so good.
