68' camaro dynacorn body build up...?
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Ok, so if I got the notion to build one of those new 68 camaro bodies such has dynacorn's from the ground up, what would the bill of materials look like? Just the major items...add to whatever my list is missing or not correctly listed as.
- new body, complete with all needed sheet metal, fenders, rad support, hood, grill, fuel tank, etc.
- front suspension complete w/hubs, rotors, etc.
- rear end complete, rotors, axles, shocks, etc.
- transmission with driveshaft, coller line, etc.
- engine complete, w/radiator, a/c system, supercharger (WTF!), etc.
- wheels & tires.
- Complete interior.
- glass and weather-strip package, complete.
- wiring harness, entire car.
- complete light package, all lighting for the entire car.
- paint & body work package.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
A subframe for front and rear!
There will be so many little things you'll need to do this. I'd consider purchasing a factory assembly manual before embarking on the build just to read up and see all the little parts and pieces you'll need to locate if you aren't starting with a donor car.
Derek
Derek
A VIN...
You should search around Team Camaro. I seen where some builders are not liking those bodies too much.
