Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
ls1 camaro 6speed top speed in gears 1-6
Old 01-10-2008, 07:14 PM
chvycmaroz28's Avatar
Default ls1 camaro 6speed top speed in gears 1-6
hey guys, im jw how fast a stock ls1 camaro 6spd with the stock 3.42s will go in each gear i was thinking like 45,80,110,?,?,? but im not sure
Old 01-10-2008, 08:21 PM
come on guys, someones gotta no
Old 01-11-2008, 10:02 AM
Arctic2002ss's Avatar
Try this: http://www.f-body.org/gears/
Old 01-11-2008, 09:03 PM
that says itll do over 190 in 5th haha i wish
Old 01-11-2008, 09:34 PM
king2000z28t56's Avatar
got a cam so i get a little more mph per gear, but heres mine 1st-50,2nd-85,3rd-115,4th-135, 5th- 155,6th- it goes forever
Old 01-11-2008, 09:37 PM
z28berryhill's Avatar
if your stock i would guess like 175 ...i dunno its a guess
Old 01-12-2008, 02:32 AM
arioch's Avatar
that had me laughing over here lol
Old 01-12-2008, 06:47 AM
It will if you've got the horsepower and raised rev limiter. But yeah, a more realistic number for stock is 170. I have been close to 160 and am confident that my car could do 180. Pegging the 155 speedo is plenty fast enough for me though.
Old 01-12-2008, 07:58 PM
how much top speed would u lose from going from the stock 3.42s to 3.73s in a 6spd
Old 01-12-2008, 10:26 PM
MICAH HERRON's Avatar
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
The best I could get with my 1999 stock M6 (SLP LM and LID) in 5th was 155mph. Not sure in 6th, because I didn't have all day.
Old 01-13-2008, 06:35 PM
Moderator
davered00ss's Avatar
LS1 f-bodies actually hit top speed in 5th gear due to HP being the limiting factor. So changing gear will actually not hurt a stock ls1 on top speed.
Old 01-13-2008, 06:37 PM
Moderator
All day? I can hit 155 in 20 secconds or less.
Moderator
from 0 that is.
Old 01-21-2008, 10:47 PM
binks0678's Avatar
ive been curious about this also, if you go to 4.10's in an m6 will your top speed still be in 5th gear which would redline at 151 or would you be able to partially pull 6th gear to say 160-170?? not that i will ever find out i jus want to know
Old 01-22-2008, 12:30 AM
BLACK2001SS's Avatar
my car stock auto trans cut out at 166 mph on a gps hand held device which is pritty accurate.
Old 01-22-2008, 02:00 PM
jason02Z's Avatar
sounds like a bmw m6 forum here lol. i got one around here thats all about goin 200
Old 02-03-2008, 02:41 PM
dogger's Avatar
stock car with limiter removed the most I've ever seen was about 165mphand that's was with several diffrent car's. 6th gear doesn't pull any higher then were 5th gear got you too. to much wind restance. also the limiter is 156 or 159 I don't rember which right off the top of my head.
Old 02-29-2008, 02:35 PM
pscmj84's Avatar
For a 6 speed, you should see about 50 in first, 75 in second, and right around 100 in third. I don't know what the top speed in gears are beyond those.
Old 02-29-2008, 03:53 PM
Big Bird WS6's Avatar
stock limit is 157.
trans ams will go 165.
camaros will go 163
and trans ams with liights up will go 161.
Old 03-10-2008, 11:01 PM
BBadPerformance's Avatar
I pulled my 02 Z28 M6 to 161 by the Nuvi Nav. System and the car is stock with a SLP LM2 Exhaust and if you pull that in 5th gear and then shift to 6th
it will fall back to about 138
Quick Reply: ls1 camaro 6speed top speed in gears 1-6
