need help identifying conectors in harness!
im wanting to clean up my m6 harness a little bit and rid it of emissions etc.
cananybody tell me what these go to...
this one has an air pump wire running from it, through the firewall, to one of these connectors. can you tell me what these two go to?
the top pic is one of the factory f-body connectors that mounts on the passenger side fenderwell. there are 3 of these and 1 single connector (purple wire for starter), and all these ran to the factory underhood fuse panel on the 4th gen car.
The bottom pic, those 2 connectors run into the interior harness of the 4th gen car and stuff through the Firewall underneath the factory 4th gen ECM location. These connectors hold your wires that run you guages, oil pressure guage, fuel pump wire, etc.
in the top pic, the brown wire is the air pump wire. it runs into that connector. pin#36, red connector. would i be ok to eleminate the connector all together? would i be ok to eleminate the to connectors in the bottom pic? i plan on using mechanical gauges.
