1st Gen Datsun Z car LSx Swap In-Progress
Too cool. gotta love it. I want that voodoo cam in part because a couple of guys claim it is one of the best sounding cams at idle that they have ever heard.
What rear gear ratio are you running?
I can only imagine what yours does with the bigger cam. Everyone says that cam is not so big that you miss any low end grunt.
Keep us posted.
Keep us posted.
I am running the stock R200 with 3.54 gears.
I am not sure if its because its a 6.0, but I am not lacking ANY low end grunt at all.
What motor are you running in your Z?
An LS2 crate motor. Not too different from what you have
http://paceperformance.com/index.asp...&ProdID=178558
I had planned on swapping some worked over 5.3 heads on my LQ4 at a later date which would raise my compression to around 11:1. However until I get my traction issue straightened out I don't think adding more power on tap would be wise.
Well I've managed to munch a set of spider gears in the stock R200 so I just welded everything up (poor-man's spool) until funds allow a LSD unit with CV's to replace it. I have also started messing with the bodywork again. Hopefully I'll have a budget paint job on it by June, but time will tell.
I am also have plans in the future to replace the truck intake with a Edelbrock Pro-Flo intake. I have the hood clearance, and its just alittle more $$ than a stock LS6 intake and half the cost of a FAST with greater gains.
You have to take that sucker to the strip and make a pass with it.
A friend had a 260Z with a stock LS2 and larger cam, JTR headers, a tune with a T56 transmission and it went high 10's@130mph+ the first time to the track on drag radials. Those old school Z cars are light!
#33
I welded a plate to cover the manual shifter hole, then mounted the shifter to the plate as if it were any ordinary trans tunnel. Same goes for cable routing.
#34
Yeah, I am not sure that is going to happen. My girlfriend [now wife] hated me drag racing so I promised her before we got married that I would retire. She gave up smoking for me, and I hated that too, so I guess we are kinda even.
I miss drag racing alot, but I like being married more.
#36
#37
#38
I'd like to help with the paint and bodywork ive painted 4 motorcycles and my 96 ws6. for exchange in helping me with my 69 firebird lsx swap. I'm no pro but have gotten pretty good with the painting, plus i have access to a booth. i posted pics here
https://ls1tech.com/forums/appearanc...inted-ws6.html
#39
