1937 Ford LS2 Install
Ken,...the car looks great! From the pictures, it looks like every thing is falling into place, and it shows how much thought you have put into it. I wish I had your fabrication skills, and especially your shop and tools! LOL.
Now, at the risk of hurting your feelings, I have to question a couple of your choices. First, that 8" Ford rear axle. I'm not even sure there is a posi-traction type differential available for that rear axle, and if there is, they have a very limited gear selection. Why not use a 9" axle, or even a later 8.8 out of a Mustang or something. Just my .02 cents worth. Also,..unless you are the kind of guy that just likes to cruise or you just like to put on a smoke show and show everyone how much power you've got on tap by spinning your tires, you"re going to wish you had used a different rear suspension system. If you put any kind of tire on there that will hold the kind of power you will be making, I can almost guarantee you will not like those rear springs.
Please don't take my comments the wrong way. I really like the car and I can't wait to see it at the shows. I just hate to see a guy have to redo a really nice finished car. Ron
I understand Exactly what you are talking about....I have gone thru my "Tire Smoking" days and they are behind me.....The 8" Maverick rear will be fitted with a mid to upper 3 series ring and pinion w/posi and Disc Brakes.......I know what you are saying about the stronger rear, but, I'll never get enough tire under the car to where I should have to worry about breaking it....."And"......they are the perfect width rear for a 37.........the leaf spring set-up, although "Not" high tech, "Is" a great riding simple option........been down the Coil Over road and hitting the correct spring rate is a PITA......I'm just building a "Neat" old Car that will go down road....Need to get there in comfort and dependability.....Next years Power Tour Car.......
Didn't get too much done in the last week.....brought all the sheet metal down to the shop, I had the fenders, etc.....stripped back in 2000 and they have been sitting in the basement and had a little surface rust on them.....after talking to M22Mike and Grady at the Nova Nat's I was informed about Acid Etching.....So...I have been cleaning the sheetmetal back to as "Stripped" condition.........Great Tip......I'll post some pic's next week....
The only problem with this basically Rust Free car....is that sometime in it's past, the original fender welting was removed (A Cushion between the Painted surfaces for the bolted on parts) and someone used a Fabric type material that retained Moisture and caused some rust in these areas......So...I need to repair these areas as I re-install the Sheetmetal for final fitting and Radiator placement....Simple stuff.....just time consuming
Ken
Ken
Looks good !! Is that Vintage Air? I'm using a Gen2 Super Cooler and Sanden 508. I'd like to know what you're doing for the AC tie to the computer.
I'm doing a 1958 Volvo which is about like a mid 40's Ford. It had an X frame too. I took it out entirely and made a tranny crossmember that can resist frame torsion (somewhat). I back halved and channeled the car. I used a Heidt's M2 front end but ended up narrowing the same crossmember you have there almost 6". I had to notch for the PS rack fittings and will be soon notching for the AC compressor.
I love the fab work.
I've got a 2 door sedan (1942) sitting around for someday. It will be a mild one too kinda like what you're talking about but not so finished. Probably my 12 year olds first car.
I'm not that far along to know "IF" it will be tied in to the Computer......All the Harness's are at Speartech waiting their turn in line for modifications.......I'll let you know how it all plays out......
Ken
Ken
Started mounting the sheetmetal today.....Aligning the front end on a 37 is a real treat......starts with the inner fender panels and you have to work up from there and I need to get everything to fit with the Hood......Here's a shot with everything loosely bolted together.....This fitup is what makes or breaks a 37.......
Ken
Ken
Here's my '68 Biscayne, back in the day. 427/425, 4 spd, 4.10 gears. It was a Beast. One of the most fun cars I've ever had.
By the way, I have a Maverick 8" in my Studebaker. 3.80 gears with Trac Loc. Perfect width and seems to do the trick for what I need. Has even held up to some abuse at the track. Street tires are my safety valve.
Pat
Pat
Nope!!.............Haven't taken the body off the frame yet....I want to get all the everything fitted, then I'll pull it off.........I also want to get rid of the stock Ford rear crossmember , I'll fab a tubular one for the shocks at that time......also to get more room for the exhaust to go over the rear axle housing.........
Ken
#32
Pat
Pat
Not to change the subject....but.....Love your Biscayne......Mine had a 3.90 with a close ratio.....Car was Insane, but....I couldn't drive any distance.....changed the rear to a 3.08 and put in a Super T-10 with a 2.88 first gear.....I can now drive anywhere, but the trans is now the weak link (2.88 first gear is only rated to 325 lbs of Torque)......By the way I'll be in Reno for HAN...staying at the Atlantis.....hope to get over to the A&W and meet you guy's......
Ken
#34
Just got home from Hot August Nights.........Now it's time to get back to work on the 37.........
Here's a link to a To of pic's from HAN
http://www.yenko.net/ubbthreads/show...e/0#Post413893
Ken
Ken
#35
Took some time today to repair a previous "Shoddy" repair of the Hood......37 Fords had a tendency for the Hood "Cracking" in the prop rod area.....and this one is no exception......whoever repaired it in the past did it with Brazing Rod (a couple of pounds worth) and Warped the Hood pretty good......
Here is the straight Passenger side
And the "Warped" side........
Brazing........... (to be cut out)....LOL
Gotta start somewhere.........
Replacing the damaged area.........
I'll finish trimming and add the bottom flange tomorrow
Ken
Ken
#36
"Also"........Talked to John at Speartech today about the Harness he is reworking......I'm going to build the GTO gauge module into the dash and even though it won't be 100% functional...it seems we can get the Speedometer, Tachometer,Temp gauge, Oil Pressure, Trans Shift Indicator,to work....the gas gauge won't work so I'll have to do something else there.....But....I should have it back next week...long before I need it.....LOL
Ken
Ken
#40
Ken
Ken
I considered going with a factory type cluster, too. What's the issue with the fuel gauge?
