5.3L LM7 in a '60-'66 Chev truck...
Old 08-26-2009, 08:13 PM
rwd1342's Avatar
Default 5.3L LM7 in a '60-'66 Chev truck...
Will F car exhaust manifolds bolt on this engine directly ?
The '03 5.3 truck engine that I have installed is wide at the exhaust flanges and I've heard that the F car manifolds are narrower at the flanges. I have notched the frame for the manifolds, but it looks like it'll be tough to bolt exhaust on.
Also, does anyone know where I can obtain A/C compressor HI/LO fittings for the 5.3's Denso compressor. The compressor tucks into the RH frame rail and I really hate the idea of notching the frame in this area.
Old 08-27-2009, 08:29 AM
V8Rumble's Avatar
Originally Posted by rwd1342
Will F car exhaust manifolds bolt on this engine directly?
Yep, should bolt right on with no issues. Post pics, I'd like to see your project!
Old 08-27-2009, 09:10 PM
rwd1342's Avatar
So they bolt right on, but are the exhaust flanges indeed narrower to offer more clearance at my frame? I'm not sure how to include photos at this time, I'll have to figure that out when I have time.
Old 08-28-2009, 11:44 AM
glock35ipsc's Avatar
http://www.nostalgicairparts.com/air...apters-592.php
and
http://www.coldhose.com/cat/compressor-adapters-25.php
$25 for the pair from both places.
Old 09-01-2009, 09:15 AM
Clyde65's Avatar
Default 60-66 LS truck install
Did the 98-99 F-body exhaust manifolds work? I am in the same boat.
Thanks
Old 09-04-2009, 10:38 PM
rwd1342's Avatar
Originally Posted by glock35ipsc
Thanks for the reply.
But my frame clearance will not allow these fittings either. I literally have only 1.250" to work with. I've ordered some from Doc's Blocks that are supposed to fit, they have tubes that come out of the fitting at an immediate right angle and are less than an inch tall. We'll see.
Old 09-04-2009, 10:49 PM
Could you post a link to those please?
Old 09-04-2009, 10:53 PM
rwd1342's Avatar
I don't have a link to them, sorry. Ordered them the old fashion way, paper catalog and the telephone.
Old 09-23-2009, 07:55 PM
rwd1342's Avatar
The F car manifold was the answer for the LH exhaust clearance issue.
The A/C fittings from Docs had to be modified to fit the tight spot that my compressor is in.
Old 09-23-2009, 09:27 PM
LS 60 APACHE's Avatar
im trying to figure out my exhaust also.think im going with the 67-72 truck doug thorley ls swap headers.i hope they will work on my 60. rwd 1342a can you post a pic of those a/c fittings and your project? what year is your truck?
Old 09-23-2009, 09:34 PM
Yeah, I'd like to see some pics of the AC fittings too.
Quick Reply: 5.3L LM7 in a '60-'66 Chev truck...
