What idle MAP pressure have you guys seen on higher lift cams?
Old 10-05-2009, 03:20 PM
LS1-450's Avatar
Default What idle MAP pressure have you guys seen on higher lift cams?
Specifically, 224/224, .596/.596, 114 or similar. What MAP pressures have you logged during idle?
Old 10-09-2009, 01:26 PM
Aaron91RS's Avatar
It's not lift as much as LSA affecting that.
My 112 lsa idles at 40-50kpa which sucks because it's pig rich.
Of course you touch the gas and it jumps down to the 20-30 where it belongs.
Never can find any really good threads on tunning this. I mean if I change the SD tables is that the fix or how much is the MAF overriding this at idle? Should I lean out the MAF table at where it idles?
Quick Reply: What idle MAP pressure have you guys seen on higher lift cams?
