Corvette power steering pump -an fitting?
Old Jan 6, 2010 | 09:57 AM
73 nova guy's Avatar
Default Corvette power steering pump -an fitting?
ok i got a 16mm x 1.5 o ring fitting from a friend to try see if it fit my pump and it does but the only problem is its so close to the pulley on the pump you cant thread a -6 fitting on the pump without hitting the pulley on the pump. is there any other option?
ill post a picture later of the pump.
Old Jan 6, 2010 | 08:34 PM
john 67's Avatar
I went to the junk yard and took some original power steering hoses off a few ls or vortec motors , cut the ends off and used which one fit best . it is tight there . I also used an original fitting off my original box and had a shop nearby make up a hose with the correct ends. JOHN
Old Aug 24, 2013 | 03:13 PM
sinistral leo's Avatar
Any update? I'm having the same problem...
Old Aug 24, 2013 | 05:32 PM
130fe's Avatar
Thumbs up
Look at this post from http://www.pro-touring.com/general/m...747-page3.html post 47. I also plan on using this fitting from Detroit Speed #090401 $18, it is shorter than the the russel brand one. Next post will have another pic (having trouble uploading them to this post).
Old Aug 24, 2013 | 05:33 PM
130fe's Avatar
Thumbs up
Pic#2 DSE fitting
Old Aug 24, 2013 | 05:42 PM
Rocketrod's Avatar
That's actually a pic from my build thread. As the pic show it does provide more clearance between the pulley and fitting.
Old Aug 24, 2013 | 05:53 PM
Awesome, I'll give it a shot. Thanks for the quick reply!!
Old Aug 24, 2013 | 06:01 PM
Would this work? I think it would give me even more clearance and I wouldn't have to remove the original outlet
http://www.detroitspeed.com/Steering...e-fitting.html
Old Aug 24, 2013 | 06:08 PM
KY Nova's Avatar
I got the DSE fitting, although it was better, you can't press the pulley all the way on. It likes .180" to be fully pressed on. I turned me a washer at work that is .1795" and am going to bolt it on the front to insure it doesn't come off and mess up a lot of crap. Between me and another forum member we bought several different pumps and pullies trying to fix this. We both were running procharger LSX transplant setups. Procharger didn't have a solution because the setup was never put in a car they said.
Old Aug 24, 2013 | 06:15 PM
I am not sure what you mean. Do you mean you are going to put the washer in front of the pulley and use a bolt in the pump shaft to get the proper alignment? Does the banjo only interfere by .0005"
Old Aug 24, 2013 | 06:48 PM
KY Nova's Avatar
Yeah, the washer goes on the front and bolt goes in the front of the shaft. No banjo fitting. It's the DSE that's pictured above. I'll try to find the pics showing the fitting in and hose fitting on it.
After Bristol race is over. HE HEEE HEE
Old Aug 24, 2013 | 07:40 PM
superdave84's Avatar
The link on that other forum to buy the fitting gives me a 404 error. Anyone have a working link?
Old Aug 24, 2013 | 08:28 PM
KY Nova's Avatar
Pic#2 DSE fitting
What pulley did you use?
Old Aug 24, 2013 | 08:40 PM
S10xGN's Avatar
I'll have to get a pic of mine, I used a DSE pressure/flow reducer fitting in the pump and a -6 x 45° AN fitting from that to the rack...
Old Aug 24, 2013 | 08:46 PM
Any chance you know the part numbers of what you used? Or can you post a link?
Old Aug 24, 2013 | 08:57 PM
KY Nova's Avatar
How about a picture of it?
jamier2's Avatar
I was reading through the instructions that came with the GMPP Corvette accessory drive kit and it mentions an adaptor that will work. I can get the part number tomorrow if it'll help.
Old Aug 24, 2013 | 09:01 PM
That would be great, thanks!
Old Aug 24, 2013 | 09:08 PM
KY Nova's Avatar
X 2 ^ ^ ^
Old Aug 24, 2013 | 09:32 PM
S10xGN's Avatar
It was a Billet Specialties valve. I remember buying the DSE valve thinking it was to go into the rack, it didn't fit so I returned it and ordered the BS valve. When that came in (and looked the same) I finally snapped and realized it went in the pump and not the rack. The BS valve has a -6 male outlet and I made up a SS teflon hose with a 45° end to fit. It looks close and was a PIA to get in and tight, but there's lots of room.
Attached Thumbnails Corvette power steering pump -an fitting?-100_2656.jpg   Corvette power steering pump -an fitting?-100_2659.jpg   Corvette power steering pump -an fitting?-100_2658.jpg   Corvette power steering pump -an fitting?-100_2660.jpg
