Single Turbo LS1 Notch Build *videos*
#41
i bought the tci 773 flexplate, i needed the 774 flexplate because my converter has teh bigger bolt spacing. i dont know what crank it is. my converter has the spacer built on, but they sent one with teh flex plate
#43
would u be able to get a better shot of the powder coated wheels. i am getting my prostars done this upcoming week and would love to get a better look of how the finish will come out
thanks and great build good luck with it
#48
update, i wired up the starter, it cranks over. if i added fuel i could start it. merge pipe turned out pretty good. was able to use a pice of flex on both sides, wastegate location works out very nice. need to send the computer to frost, buy a 3 bar map, few small things and ill be getting my drive shaft threw pst. i had their aluminum one in my camaro, but ill stick with mild steel and a real 1350 pinion joint, and ill do 3.27's at the same time
better pic of wheels.
93 cobra rear disk conversion
had to get and adjustable one because stock was putting pressure the wrong way
merge pipe
merge pipe
#58
i should be able to start it up in a week or so. gotta wire up the 3 bar map, finish welding the wastegate to merge pipe install the 02 sensor bungs, make down pipe, weld iat and bov to charge pipes. gotta cut up the radiator and angle the lower hose. ill order my drive shaft once i mesure it out. gotta buy a new brake master cylinder. im still aiming to have it down in ocean city for the srping show
#59
