Engine wont get out of it's own way
I was giving +/- a few just because the guage is old. Dont tell my mechanic I said that. I pinched off the return and the pressure guage went full, all the way pegged which is what it should do, also it should run well at idle even if it only had 50psi I would think, wouldnt it?
OK, got something for ya, the ds header is barely warm, the pass side is scalding hot, all injectors are getting the reqd voltage and are firing as they should but it runs like crap, I have a set off the 05 and Im going to put those all the way around and see WTF. I will let yall know.
Fixed!
bad injectors on the ds. replaced all injectors and it runs good now! wheeeeeew!
BTW Anyone have a 99-02 fuel rail set they want to part with? Mine has a crease in a place I dont like.
Not if you talk to Jesse, he is the greatest tuner on the planet, used to work for GM, doesn't make mistakes, and he'll be sure and tell you that several times on he phone.
[QUOTE=eviltwin_1987;13165897)
my brothers nova, mail order tune by wait4me, runs like **** except for idling too. it seems like 1/10 tunes from them actually work good
[/QUOTE]
Did re-tuning your bro's pcm fixed the problem?
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
#32
5 of 8 were nasty dirty, the trash came from the fuel rail that looked like it was stored under water on the inside. Jesse's tune wasnt it at all so I have no issues there.
btw what are yall using for lower rad hoses?
Thanks
Thanks
#34
I have a different fuel rail now, used the summit connectors that connect the slide on stock quick connect to the -6 I have for fuel hose. Now I am just cleaning stuff up wires and such. should have on the road and DD mode in a week or so.
I appreciate yall helping out, giving suggestions to guide me in a direction to resolve, that is what I like about this sight.
Clyde65
Clyde65
#35
You mention grounds to frame, are there grounds from back of block to the body? Although my rig is much older and had several body bolts going through body to frame I had a slight higher rpm miss and had several ground straps everywhere, can not stress enough about grounds especially when dealing with modern day electronics. I also had jesse do my ecm for me and for the most part was OK, he left all torque management on which when punched would fall on its face.
#36
#37
I have the body to frame( 2X), frame to engine(2x) and engine to body (1x), I would hope that is enough grounds, I also grounded the bed to frame in back ( this helped on my LED light alot!).
I too would think it would be a given, now ya got me curious. I am gonna check that tonight.
