Lsx Charger, considering the swap
Old 04-30-2010, 08:38 PM
Rick Speed's Avatar
From my experience it would actually be easier to swap in a LS1 then to swap in a Hemi.. getting rid of all the mopar computers will help alot. Just ask pick-a-part they've done Hemi swaps and its a real bitch to get them to work perfect.
Old 04-30-2010, 09:16 PM
Palomba's Avatar
Insurance would be a lot cheaper with a LSX swapped into the v6 car rather than the SRT8 version.. Would be original. But if you do it do it right. I believe you would need to run a new DBW pedal setup that would work with the throttle body on the LS motors. LQ9's can be had for pretty cheap and modifying LS motors is a lot cheaper than the HEMI and more options out there. But it wont be cheap to do. Wiring will be your pain in the ***. A stand alone harness would be the way to go and find where to spice in for your gauges and such, or run a custom cluster.
As far as the e-brake goes, if its just a straight cable you could pull the hand brake assembly from a car and bolt it in, and hook up your cable.. adjust the length to where you need it and i would think you should be good to go.
Old 05-25-2011, 01:01 PM
LS1LOL's Avatar
I have an '06 2.7 Charger with 190k on the clock. When it lays down, I intend on swapping in a 6.0/4l80e. It'll be paid off in a few years and resale value with this many miles is crap, so I might as well keep it and have fun with it. The cars themselves are awesome, tons of room front and back, huge trunk, and plenty of room under the hood.
Old 05-25-2011, 01:06 PM
LS1LOL's Avatar
I'm assuming the pedal e brake is a concern since you're planning on running a six speed? I'm staying automatic with a stall. The motor will have a cam and maybe heads, nothing over the top since it will be daily driven. A car my wife could jump in and go to the store in. Thinking a stock axle back from a gen 5 Camaro would keep things quiet, with cut outs of course
Old 05-25-2011, 02:32 PM
WeeWolf's Avatar
Cluster and a/c run off the CAN bus so that would be my concern is how to incorporate the two electrical systems.
Old 01-13-2013, 11:37 AM
tonytone4143's Avatar
was this swap ever done?
Old 01-13-2013, 02:06 PM
the_merv's Avatar
LS1Tech 10 Year
I'm curious aswell..haha..this is an old thread.
Old 08-04-2013, 11:16 PM
s/clsxmagnum's Avatar
Here is mine. Yes it is possible. The gauges are aftermarket stock sucked any way.
Old 10-08-2013, 12:21 PM
fastbird02's Avatar
omg, that thing is a beast!!! nice swap! have a build thread??
Old 10-08-2013, 06:54 PM
kevin99hoss's Avatar
sick magnum swap, i was wondering a few days ago if this swap has ever been done to one or a crossfire.
Old 10-09-2013, 08:29 AM
retardedpenguin's Avatar
Craigslist ls1 Camaro $2,000
Fuel system $300
Custom mounts $150
Wiring and tune $300
Hoses $100
Driveshaft $250
Random **** $500.
So you have like $3500 into it. Part out the car and make $1000 back. This list is literally all you need. Swap the 4l60 in too.
Why wouldn't it be reliable? The engines are standalone they will run as long as there is constant and ignition. The wiring would be a little tricky for the gauges, but with a gauge pod and the speedometer app on your phone it would run just fine with a simple swap.
Old 10-09-2013, 09:53 AM
  #32
HO99Vertz28's Avatar
Originally Posted by hyespeeder
Hey everyone here is right about it being a headache and alot of work and the price might add up.. BUttt.... that car would be the only charger with a ls motor ... that = a cool rare factor that everyone will be like wow ..... and with the ls motor upgrades such as cam heads ect..... are very cheep easy to get and easy to install....
I would defentaly do it if i had the charger .... Dodge engines are JUNK they need a hemi to get close to ls3 power imagine if the ls3 was a hemi lol wow ....
DO IT
We are here to help .....
You're a ******* moron, seriously. Let's see...Dodge's JUNK 6.4 puts out 470hp...Gm's junk new direct injected turd only does 450...
And the HEMI bs, is just marketing. Go learn something, then come back.
The following users liked this post:
Doug Lynch (07-27-2020)
Old 11-27-2013, 11:11 AM
  #33
Default lq4 6.0 4l80e magnum s/c
Thanks! No build thread. Just a quick drive way build!
Old 12-01-2013, 03:17 AM
  #34
BrianAg 707's Avatar
im also thinking on doing a ls1 swap on a magnum, were could I find a correct motor mount, nd how did you get the gas pedal to function
Old 12-01-2013, 07:16 AM
  #35
aknovaman's Avatar
LS1Tech 10 Year
This is a great thread, almost 4k views and zero pictures of an actual build :-(
. Anybody gonna build and document one of these other than a fuzzy video in the dark.
Old 02-26-2014, 07:18 PM
  #36
I used trans adapt motor mounts then built aluminium adapters to stock location. I used 1/2 x3 aluminium plate to make trans crossmember. i modified stock truck manifolds. drive shaft was built and adapter for rear diff.
Old 11-08-2017, 08:54 AM
  #37
Dlake7's Avatar
Default 2009 Dodge Charger RT LSX swap
I have a 2009 Dodge Charger RT 5.7. Im looking to do a LSX swap. What all will I need and cost with parts/labor? Thanks!
Old 11-08-2017, 10:14 AM
  #38
AnotherWs6's Avatar
9 year old goggling???
Old 11-08-2017, 10:28 AM
  #39
Dlake7's Avatar
Do you have any info on a Hemi to Ls swap?
Old 11-08-2017, 11:09 AM
  #40
Received 3,240 Likes on 2,525 Posts
If you have to ask, you better keep the 5.7 Hemi....
Quick Reply: Lsx Charger, considering the swap
