Park Neutral switch needed in swap?
Do I need a P/N Switch in order to have lockup and overdrive?
What input does the PCM need for TCC lockup? 12v, 5v or ground???
I recently swapped a 4L60E in place of my TH400 in my LQ4 powered 1990 Firebird. I'm having troubles getting torque converter lockup and overdrive to work. I'm running a Speartech custom harness with 4L60E controls. It doesnt have wiring for the P/N switch but only the Speedo sensor and the main connector for the valve body and solenoids.
cool. I definitely have the purple tcc wire from the car connecting straight to the tcc wiring in the custom harness. Looks like Ill have to do the relay. Now I just need a schematic or a description of what the relay needs.
The tcc needs 12v+ constant this locks the torque converter. When the brake is applied the 12v+ is switched off. They sale a brake switch that does this. the standard GM brake switch applies 12 volts when the brake is applied. You need a switch that will do both.
The park neutral switch also controls the idle you need it also.
T,
your brake switch will work fine with no added relay. An original 700r4 car should have the correct switch with normally open (NO) and normally closed (NC) contacts. If you have the wire leading from it that is hot with key on and the power dies when the brake is pressed then you are good to go on that end.
What kind of shifter setup do you have that has no place to hook up the park/ neutral wire?
