Ls1 into a 1995 Mustang
I am just beginning to dive head first into this..
I picked up a 95 mustang for next to nothing and i want to attempt this project i have always wanted.. I want as many tips as possible from you guys! I would assume that much of the fox swap components (such as K member) would also work in an Sn95 as they are both technically fox chassis cars (correct?) also kooks swap headers will also work i would assume? if anyone has attempted this swap could you link me to it or provide me with any pictures etc? thanks!
I'll give you $200.oo MORE than you paid. Easiest $200.oo you'll ever make.
AJE kmember and mounts
Dynatech headers for stang/lsx swap
Those are a easiest way to go.
there are several cheaper ways of going but definitely more time/labor will be required
its still a fox chassis your correct. i would imagine the same steps to put a ls in a fox would be needed to put it in a sn95. there is a guy on the svt site that has done ls swap in a sn95
wiring isn't too bad on a 95
If you run power to the underhood fusebox I believe all of the accessories will still have power and work.
You then need to send power to your new engine harness/ignition and get the start wire to the new starter and everything should work correctly
