Sally is a Dirty GIRL LS1/99 f-150
Hey guys...before the flaming starts...i just want you to know i am excited about doing this conversion. and i fully understand that putting an ls1 in a 99 f-150 is sorta sack-religious..with that being said... I DONT CARE...and i came here for help!
SO FLAME AWAY! i love my truck and i hope this motor is as amazing as everyone says it is...
So i am a newbie to the ls1, but i have done some conversions such as a 3.8 GN motor in a toyota and a couple others.
So i have a 99 ford f150 extra cab Long travel pre-runner and her name is Sally!
It started off looking like this...
then i bought some suspension for it..
took the bed off and did some other mods..
and now this is what it looks like..
and last but not least...the new motor that is going to go into it!
this build is solely for offroading/prerunning. I like simple and yet effective vehicles. There will be no turbo/blower setup on this motor.
i want a naturally assperated 400hp motor or so...to put in my truck. I heard the LS1 is a great starter.
So things i was hoping to get help with...
simplest way to get to 400hp and what tranny i should use..and any other help i need along the way would be greatly appreciated!
and what cam do you guys suggest?
headers/exhuast is a given..
it has ls6 intake already on it.. i would like to get a painless wiring kit...or somthing similar...any suggestions?
And I don't think you'll be dissapointed with it. Cool project, keep us updated.
thanks guys! I havent had anytime to even look at this motor since last week.
I have been doing some research thats it.
What cam would you suggest for what i am trying to do...sand/dezert is very high rpm...i would like this motor to be bullet proof before put alot of effort into getting high HP output.
do you have suggestions on who i should go with for a standalone wiring harness...
i plan on running both of mine...and the LS1 so i can keep stock windows and so forth going.
just some teaser pics...of my suspension build...
i will be tearing the motor out soon i hope..
gotta figure out what tranny to run...
LS motors are showing up in a lot of sand rails and buggys. You might check with them to see what mods they are doing for power and survival. If sustained high RPM is the plan, you should change the rod bolts. I would pick a couple of the LS1Tech sponsor cam companies and tell them how you will drive it, vehicle weight etc and let them recommend a cam. Other mod suggestions I'll leave to the more experienced.
That looks like awesome fun.
IF he is missing the harness, PCM and sensors it may be cheaper to go carb unless you can score some deals.
Good luck on the build!
www.currentperformance.com
i got my stand alone harness from them. very straight forward and easy to install.
