dont know where to post....5.3 vs ls1
Old 12-21-2011, 08:31 PM
ls1wrx's Avatar
Default dont know where to post....5.3 vs ls1
will the drive accesories off a 5,3 work on an ls1? i want to run the ls1 intake and water pump. all i need drive wise is crank pulley,power steering, alternator. please help asap....
Old 12-21-2011, 08:35 PM
2165 Turbo Rail's Avatar
yes it will work.. you just have to cut off the idler pulley and relocate it.. I'll post pics of mine in a second.
I put a LS1 intake on a 6l truck motor so its the same you are doing basically
Old 12-21-2011, 08:40 PM
here are some pics
here you can see where we cut the idler off beside the alternator
here you can see that the idler is now below the alt pulley
***EDIT*** the spacer was perfect but the bolt was too long, i'm not sure if they just sent me the wrong bolt or what but either way it didn't work
I just saw this on a thread by -TheBandit- and decided I'd order the same for my conversion
From Misumi USA (www.misumiusa.com), the spacer is PN KNCLM10-30-20 and cost $5.70. It is nickel plated steel, 10mm ID, 30MM OD and 20MM length. The bolt is PN CB10-160 and cost $2.40. It is M10x160mm length. Total $8.10.
Old 12-21-2011, 09:01 PM
MillsMotorvation's Avatar
Originally Posted by 2165 Turbo Rail
here are some pics
Ive read your post, but I didnt realize you were relocating your idler, is the a bolt hole there, in that bracket, where you have the idler?
Old 12-21-2011, 09:11 PM
yup it is
Old 12-21-2011, 09:37 PM
Thanks! I have a intake to swap!!
Old 12-21-2011, 09:44 PM
no prob... are you putting this in a GN? (your avatar is what is making me ask)
Old 12-22-2011, 06:56 AM
garys 68's Avatar
LS1Tech 10 Year
I did the same thing, but added AC.
You'll need the truck crank pulley and a new bolt for it.
Old 12-22-2011, 07:29 AM
True since you are putting truck acc on car motor I used a truck motor so I had the crank puller already and I mounted the ac comp in its stock location.
Quick Reply: dont know where to post....5.3 vs ls1
