Fixed and variable displacement A/C compressors
Old Dec 24, 2011 | 10:31 AM
big johhny's Avatar
Default Fixed and variable displacement A/C compressors
I am swapping an LS2 from a 2005 GTO into my 70 Lemans Sport that has the factory R12 system still intact. I know basics about A/C but this is bit much for me.
I have to relocate the compressor on the LS2 up top so I don't need to notch the frame. the brackets will allow me to use a Sanden fixed displacement compressor. I want to keep the Lemans evaporator since it is factory. I can redo all lines no problem and figured I could get a new filter/drier and orifce tube for the GTO and adapt it for use. I have the old ones but assume I should replace them. I also want to use the condensor from the GTO since it fits nicely on the Ron Davis Radiator that was on the Goat.
The GTO uses a variable displacement compressor, will a fixed be a problem for the Goat's components?
Any other things I should be concerned about?
Old Dec 24, 2011 | 08:31 PM
arthropraxis's Avatar
You can make it fixed by removing the valve that makes it variable. Remove the O-ring and install the valve. The compressor oil will have to be refilled. The valve can be found by looking underneath the compressor, it is held in with a C-clip and has a hex head integrated into it.
Old Dec 25, 2011 | 12:57 AM
chrisfrost's Avatar
Yes that will work fine either the Sanden or the factory variable 1 modified as described in the previous post and You can use R-134 refrigerant provided You use the proper Pag oil ,,,,,,,,the only thing You might want to do but should'nt be a problem if You don't is to flush out the system unless You've had a compressor failure You don't have to .
Old Dec 25, 2011 | 01:40 AM
speed_m5's Avatar
Please explain this better i have the compressor from a 99 f-body that i really wanted to use on my ls1 swap into my 72 camaro with vintage air but was told by the sales man that i could not use it.
Old Dec 25, 2011 | 08:02 AM
Try this link:
http://www.aircondition.com/tech/get...9WYWx2ZXMucGRm
Old Dec 26, 2011 | 10:26 AM
speed_m5's Avatar
link no workie
Old Dec 26, 2011 | 07:35 PM
Works for me. Try this one.
http://www.aircondition.com/sitesear...=rcv&sa=Search
Both of the two articles at the bottom of the page are relevant.
Old May 5, 2012 | 09:51 AM
M7A1V's Avatar
I'm thinking about going this route...could someone tell me...what the V7 fixed compressor c.i. displacement would be after this mod?
thanks...Frank
Old May 5, 2012 | 01:12 PM
jslezak83's Avatar
After reading that article, I'm still a little unsure if I can do this mod to the compressor and use the original evaporator, dryer, and low pressure cutoff switch in an 1987 S10? Is there anything more to it than that?
