LSX swap in either 91 Camaro or 93 Camaro Z28?
I'm kind of in a bind here of what I want to do with my 1900 mile 5.3L LS engine is have sitting in my garage. The original idea was to swap it into my 91 Camaro cuz the motor is getting tired and it's my first car. I have also be thinking about the idea of doing the LS-swap into my 93 Z28 cuz right now, my LT1 has been giving my nothing but problems since my recent engine swap done to it. The problem has been all electrical, mostly with the ignition (3 optis and a LTCC conversion not working and not getting any power to the module). I already have a big idea of what it would cost to the do the swap to either car.
91 Camaro: things to changes for conversion
-fuel system conversion for LS engine can be expensive
-exhaust (headers and custom y-pipe) ranging from $1200+
-new rear end and transmission
-new wiring harness
-engine mounts and transmission mount
93 Camaro Z28: things to change for conversion
-change k-member (98-02 factory f-body k-member)
-dash gauges wiring (LS harness won't work w/ LT1 gauges), probably aftermarket gauges
-exhaust (98-02 f-body headers and y-pipe will work w/ no problem, most likely go with pacesetter for money part)
-transmission (my factory 700r4/4L60 will work w/ adapter)
fuel (change in-tank fuel pump or in-line fuel pump)
I'm sure there is things that I am missing for the 2 cars. Some input on this would be great on which swap I should probably do. As of right now, I'm kind of leaning towards my 93 Camaro since it would cost me less to do the conversion than my 91 Camaro but still not sure.
-new wiring harness
For a thirdgen swap you do not need 1200 headers and y pipe. You can use stock F-body manifolds with the swap and then have a custom y pipe made for a few hundred.
The fuel system is not very expensive either as you can run a Corvette filter and use most of the stock fuel line. You will need a new fuel pump like a Walbro 255. You only need to remove the return line from the front.
A new rear end is not necessary, but encouraged with the increased power but it is no different than what your 4th gen has minus the width.
As for a transmission why not find a 4l60e in the junkyard that came from a LS car or truck and you will be fine. Some have used a 700 but it is more of a hassle than its worth.
Both would make good swap projects (I'm partial to 4th gens myself) and should both be fairly strait forward to do.
Which ever way you go, decide what you want to do now, research it and find good references to follow, plan your build with your budget, and stick to it.
And don't forget, you can fix the screwy electrinics on that LT1 by putting an LS-style fuel and ignition system on it. Conversion kits are availible for that now. Then you get a good running '93 with a '91 to swap that 5.3 in.
My 2 cents....
My 2 cents....
I was looking around and found some long tube headers for 3rd gen camaros for about $700 for a pair. I need a new rear end cuz my 91 Camaro is the RS model and its the single-tire fire rear (sucks ***). As of right now, I think I'm going to stay with my 3rd gen. I just need to get my 93 running or sell it and get a different car.
My 2 cents....
My 2 cents....
Hello,
I would say do the 1991 camaro!! I like the thirdgen's!!
Click on the link below to see my LSX build...........
And look at these headers :
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV3
And if you have any question's, i will help if i can......
Later,
Robbie
Later,
Robbie
