water pump info needed
I am doing a ls6 swap in a 69 bird and with the mounts I am using the w/p is about 3.5" from the radiator core , I am using all Fbody accessory. I was told that a G8 pump or a ls2 pump would work and be shorter? I'm hoping for 1-2" more clearance for fans- I can move the radiator about 1" forward if I redo the mounts - anyone know the differances in the pumps?
Moderator
Is there room to mount the electric fans in front of the radiator?
I did that on my '81 Camaro using a 1-1/2" deep dual fan unit.
I also bought a new water pump for my LS2. I recall that the original LS1 pump has been replace by the LS2 pump which also fits any LS1.
Check if the Corvette water pump is lower profile - maybe someone knows that answer.
