Steam port -AN adapters
J. J.
They aren't listed on the site but I see something similar are part of his vapor kit so they probably can sell them. Still not direct to -AN though. His appear to be NPT which he then puts a -AN adapter in.
I've seen them direct to -AN before, just forgot where.
J. J.
J. J.
adapters:
kit
J. J.
Thanks again for the info though.
J. J.
you need to do some more reading and getting around more
this is what i had to do.
https://ls1tech.com/forums/generatio...ines-pics.html
These are what I was looking for though. I knew I wasn't imagining them. Although that price is the thing of nightmares.
http://www.krcpower.com/catalog_i112...l?catId=366482
I don't know though. If that price is for 2, as pictured, its about in line with or better than Mr. Urban's seeing as how you're going to spend $5 or so on the 1/8 npt - AN adapter to go into his fittings.
Why plumb all four corners like you did though?
J. J.
trust me went i first got my engine running the hot air coming up out of those lines was crazy!!! the lines started jumping around and making poping sound untill coolant started to flow
so make sure you do all 4 corners
J. J.
J. J.
