66 buick skylark 5.3L, 76mm, th350 and E85
Hey everyone. I am starting my build and have a quick ?. What are you guys using for throttle cables on cars that have a mechanical linkage?
My setup is a 1966 buick skylark 4dr. 5.3L, ls6 cam, ls1 intake, 76mm turbo, th350 and E85. I will be posting pictures as I go with it.
Thanks in advance for all the help on here. I am looking forward to this build!!
figured I'd throw a picture of the car on here to start with. The appearance of the car will remain the same except for a set of color matched ralley wheels with chrome rings and center caps. I wanted to keep the factory wheels and hubcaps but they are only
14" wheels and that limits the tire size. I want to run a 235/50/15 drag radial on it. I am considering doing a white wall to the tires though to keep the grandpa look to the car
The trans is a reverse valve body, so I will need to modify the column shift to work with the 3 speed trans, it was a factory PG car.
