L92 into Rx7
L92 into Rx7
Now just figuring out what to put on it!
No power steering or AC, so figuring what to do for the accessories and drive
So far I've got on my list...
LS3 intake manifold/injectors/fuel rail/TB
katech timing chain c5r
baffled f-body oil pan/pickup
ls7 flywheel/clutch/PP
Part number Description
19207665 L99 water pump
25835421 corvette DBW pedal
12612289 L99 oil pump
12588670 ls2 timing chain damper
12628025 l99 belt tensioner
Suggestions for alternator and bracket?
LS1Tech Sponsor
Your gonna have trouble keeping tires on that thing!
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
That's what the Cobra 8.8 is for! =D
But yah, the one question I still haven't found an answer for is what alternator bracket to use. I'm thinking that even the stock one might work, but I'd like to relocate the alternator to the old power steering pump position or at least a higher position. Guess I'll just have to order stuff and find out if it all lines up or not, haha.
12610789 is the l99 alternator bracket, Thats what i would use if it will clear everything. l99 uses the same beltline as the trucks. I have found a few that use the truck beltline besides the l99 bracket. Does your l92 have vvt and afm or just vvt?
