Installing autometer gauges into foxbody
Using ultra lite series gauges.
05 5.3 set up with DBW so green/blue ecu
Where do I pull the source signal for the tach?vits already on 4 cylinder mode
And the water gauge is electric with the sender, I bought the autometer adapter that threads into the passenger side head but the sender doesn't fit into the adapter. Is there a way to tie the gauge into the existing water temp plug on the drivers head?
Those are my main problems right now as my speedo hasn't come in the maili yet
Here is a thread about getting all the Autometer gages working in my Daytona.
https://ls1tech.com/forums/conversio...er-guages.html
Oreiley had the Equus 9848 in stock. That kit should have every adapter you need (oil pressure + water temp). Oil temp and Tach can come right off the PCM.
I drilled out the fitting for the head so the long sender would work, for the tach used p10 the white wire and ended up having to wire in a 12v ignition wire with a resistor into the tach signal wire to boost power
