Lq4 fox body engine mount question???
I bought the complete kit with the control arms,coil overs and mounts...it said for small and big block Chevrolet as well as ls1.. Just didn't know if I needed anything else to bolt to it?
I would just make sure the mounts bolt to the engine and check to make sure all the hardware is there. If so, the tranny crossmember should be you next main concern.
The AJE big block small block and LSX mounts are all the same mounts. I'm guessing they would be included with your order. You only use three holes on the LS1 install.
