Steam line vent kit....
Old 02-21-2014, 08:55 PM
  #41
The highlander's Avatar
This will not fit under a FAST 102 right?
Old 02-23-2014, 08:42 AM
  #42
sparkwirez06's Avatar
Nothing will fit under a fast intake!
Old 04-03-2014, 12:34 AM
  #43
oscs's Avatar
Can someone post pictures of where you are returning the steam into the water pump. I think it will help answer some questions
Old 08-12-2015, 07:57 PM
  #44
str8nsty's Avatar
Default tfs steam line kit and lsxrt intake
The lsxrt and the ports that bolt to the heads on thr f/d and r/p sides try to occupy the same space
First pic is rear second is front.
You will need to get more fittings of different degree bends 45 and 90 to make this kit work with the lsxrt and you will still have to shave these areas to get it to fit.
Rear passenger.
Front driver. Still waiting on more fittings. The kit does not come with 45s and it uses fragola not earls. Fragola is more of a high gloss than earls plus fps on fittings.
Quick Reply: Steam line vent kit....
