LS Wiring Book
http://www.ebay.com/itm/LS1-LS2-LS6-LS7-STAND-ALONE-WIRING-HARNESS-BOOK-MANUAL-GUIDE-ENGINE-SWAP-PCM-6-0-/221843865612?hash=item33a6ecc00c&vxp=mtr
https://ls1tech.com/forums/conversio...hevelle-2.html
I still need to go through my hand diagrams and clean them up more like Jason did above.
Here's a link to some G8 manuals from a G8 forum
https://www.mediafire.com/?6l6q10bav0xof
And a link to all the G8 harness pin-outs
http://forum.grrrr8.net/showthread.php?t=33446
This is the link to LT1swap where he did an LS3/L99 which was really similar. Jason and I both based our work on this.
http://www.lt1swap.com/2010camaro.htm
This how-to on LT1swap walks through the main process, albeit a different harness, but its the same technique. Sadly it might not make sense until you start tearing into the harness. It made more sense to me once I got going.
LT1swap also shows here how to make your own fuse block and OBD2 port to make your oem harness more of a standalone harness.
http://www.lt1swap.com/fuseblock_obd2port.html
And my harness was missing one of the ECM plugs as well. I think I mentioned it in Jason's thread at the top. I had the 80 pin connector, but needed a new 73 pin connector, and this is where I got it. I also bought the special crimper to do the crimps the right way.
http://www.currentperformance.com/pr...ctors/ls2-ls7/
Hope this helps and isn't too much information at once.
