Craigslist Searching + My Apartment Room + LSx + Thirdgen = ?????
but RTS are goood and have alot off clearance from what ive seen and heard
im just speaking of direct bolt on 17" wheels for thirdgen as there not many options for direct bolt on unless there forged custom of some sort...but can get RTS direct bolt on if you spec them out correctly .. guy on TGO running 18x10.5 or 10 i believe all around with no spacers IIRC
are you putting on a thirdgen?
but good thing you can get RTS to fit most cars due to wide range of options high, low, med pad, offsets etc etc and the cheap for a forged wheel compared to other brands which is a good thing
only pet peeve is the double barrel construction with short spokes which gives the illusuion that wheel is smaller than it is so i like 18" version as its the best compromise and im not a fan of 20" wheels .. but i assume its for strength reasons..
#33
too increase oil pressure a tad
not using a double roller
#35
Thanks Tork thinking off plastidipping car a matte pearl blue and plasti dip wheel center matte mettalic gunmetal with lip matte black
I really suck painting . Got really frustrated valve covers look the worst .then said freak it ..started freestyling with the rattle can .sigh ..but just mocking stuff up
Looks black till you hit the light thats the freestyle I guess
#36
I have a 1990 IrocZ and im swapping a LS1 into it in my apartment and in the parking lot straigh backyard stuff
so im Crossing over to the dark side lol
Your not doing what you said unless you got pics well here they go
Got time today to tear down engine for inspection
Craigslist guy said there was a upper knock
Hmmmm I wonder what that might be
Found a needle bearing about 2 or 3 chilling
But wait there's more
Like my new chop stick
Tried to get good pic of cylinder wall didn't come out good
Still see crosshatch
But there is more
Looks like valentines day and someone got luck with a kiss
Check valves but didn't see damage to the bottom of any
not going to use the the heads also had a bent valves slight leak to the valve that kiss piston
valvetrain
cam bearing
better pic of what cam bearing look like
So final thoughts
Looks like they bent a pushrod it also looks like they tried to save money and just replace one push rod as this was the only clean one
i think its safe to assume that valve kiss piston bent rod and bent a valve also
Another piston had fluid in it I'm not sure from disassembly smell like fuel but could be water hard to tell used a napkin and wife said it smell like gas tho no rust spots etc
Could be gasket ? During disassembly or when engine was on its side idk not a issue im worried about tho
yes in my apartment room
But there is more
valvetrain
cam bearing
So final thoughts
#37
Did you read entire thread or just seen 1st post
If I don't do it right then I don't do it at all .. That's my motto
Why would you rebuild and reuse wear and tear items ??? Head scratch ........
I have new lifters and trays
New cam bearing... piston rings.. arp rod bolts etc etc etc
Every gaskets .. O ring .. Freezer plug .. Timing chain ..etc etc ...are new
Hope you learn a lesson with that lol we all have those moments and hope you got it fix
#39
looks great, keep it coming. Don't worry about the paint, I suck too. Paint doesn't help you do burnouts, if you make enough tire smoke you can't see the paint job, right?
