Craigslist Searching + My Apartment Room + LSx + Thirdgen = ?????
#42
i have alot of tools no hoist i know some one that has one he let me borrow to remove my old engine when it comes time i just borrow his or rent one to swap lsx engine in it not hard i do everything by myself, no help, no shop, no sponsers . im just a regualr navy guy that loves cars and if you put your mind to it anything is possible im only 27
it also helps i live on the first floor lol
just notice your from miami i am too i went to ludlum elementary ,south miami middle , miramar high and hallandale high school
Thanks
#44
little update should have engine in car at end of month if all is smooth
got parts to upgrade 4l60E
getting rest of gaskets for heads and ordering cam tommorrow spec by Pat G
#46
Little update . Life issues gearing up for move I have put the ol milk bucket on the back burner and waiting for custom cam which I miss delivery twice and waiting to pick up at local store hopefully tomorrow
Need to get back on the ball
#49
Thanks guys
very good news first i hate fedex gave me the run arounds but good nes FINALLY got the cam in my hands time to finish putting this engine together and throw her in
#50
Awesome build man. I used to want an iroc and this is exactly what I would be doing if I ended up getting one. Keep the information coming and good luck on the build.
#52
bout how much u got in that rotor/caliper setup?
tryin to decide on 5th gen calipers or afcos. wont b running anything bigger than 17s front and back. also if the ss calipers fit 17s. using a fm5 wheel so the bolts cause interference on calipers.
look like its coming along. what kind of hp u expect from that 5.3?
#53
for 17" you have to double check clearance with spokes and wheel barrel only wheels i know out of the box that would fit are CTW Motorsport wheels , it really depends on the barrel of the whell as some 18" wheels dont have big brake clearance due to wheel barrel design
also keep in mind that and thirdgen bigbrake setup will move your offset so again idk if your already have your fm5s already you should check clearance on that also standard big brake kits aka ls1 c5 c6 pushes out about .3" with standard machine hub dont qoute me im going of the top of my head ,Camaro ss with 1le hub pushs offset out about .6" again dont qoute me i have to double check but it gives a good idea
i have a 99 LS1 5.7L my goal is hopfully be close to 380ish would love to be over 400ish to the rear wheels
my part run down so far is
Mildly ported 243
Custom EPS Cam i think specs are 22X-23X @ .50 just got it yesterday
42lb inj
Stock Block Rebuilt with ARP Rod Bolts
LS6 Intake with Ported TB and MAF
Long tubes 3in ypipe 4 in cat back no cats
4l60e mildly built upgrade 3-4 clutch shift kit and other stuff etc
3600 stall converter
stock 10 bolt with zexel posi 3.42 gears
going to get mail order tune for now but will get full dyno to hopfully ill have some good numbers but more importantly the power curve and delevery
#55
lol im moving in this oct i really dont care the management is so disorganized i dont think any body in the apartment paid the full deposit amount
but def not doing it again lol next apartment is way to nice and wife will kill me for sure lol
#56
Finally got settled down from relocating and got some time to work on car been long over due
Shes all button up now just need to install valve covers, intake and accessory. Time to break open the trans to do upgrades.
