LQ9/4L80e going in a 74 Nova, gas pedal/cable Q's
Old 05-16-2014, 09:16 AM
Ryans99ls1's Avatar
Default LQ9/4L80e going in a 74 Nova, gas pedal/cable Q's
Im helping a friend get this build going and we cant seem to get an answer on what throttle cable and gas pedal to run. Ive looked through the threads and no one really talks about it.
So what are people doing to hook their pedal up to the throttle body?
The motor has an ls1 cable driven throttle body and ls1 intake. The nova is stock with a carb'd 350 so it has the mechanical linkage. Do we need to swap gas pedals or what?
Thanks for the help
Old 05-16-2014, 12:08 PM
Goldhawg's Avatar
I'm upgrading to the TBSS intake manifold now, and swapping to a cable driven throttlebody.
https://ls1tech.com/forums/generatio...ttle-body.html
Should keep the LQ9 going into my 99 tahoe going with deep breaths...
Old 05-16-2014, 12:29 PM
Ryans99ls1's Avatar
Looks like a nice piece but im looking for a gas pedal and throttle cable solution, not a throttle body..
Old 05-16-2014, 01:08 PM
bigmandengo's Avatar
Why not use the factory pedal and a lokar cable?
Old 05-16-2014, 03:24 PM
hookemdevils22's Avatar
OE Nova pedal, 36" or 48" Lokar cable. That's what I did. I believe I went with 48", but 36" should suffice.
Old 05-17-2014, 08:04 AM
oldgoat69's Avatar
Which PCM are you using? If it is the LQ9 it will need to be modified for the cable throttle.
Old 05-20-2014, 07:24 AM
Ryans99ls1's Avatar
I was under the impression i couldn't use the factory pedal?
This is the one ive been looking at, is it all we need?
http://www.summitracing.com/parts/lo...0ls1/overview/
We are running an 0411 pcm. We went ls6 intake with EV1 injectors and cable driven throttle body. Running the hybrid front accessory setup with the L99 camaro ss water pump and truck alternator bracket.
Old 05-21-2014, 10:15 AM
That works. I checked, and went with a 48" cable. Here's how I routed it - you can see I snaked it along the passenger-side fuel rail, then behind the intake due to the excess length.
Quick Reply: LQ9/4L80e going in a 74 Nova, gas pedal/cable Q's
