PSA: Needs Moar Grounds
My battery is in the trunk on my swap car. While attempting to diagnose a starter consumption (2 in 6 months) issue I found that my one lonely engine-to-strut tower ground was glowing when a friend would crank the engine over (it went to normal after the starter stopped). Adding a second strap corrected this issue as well as an ongoing charging issue and my radio cutting out over 1/2 volume. The glowing ground was about an inch from my fuel filter, so the car could have easily caught fire in the event of a leak. I've put over 15k on this car in the last 3 years.
Always make sure you have sufficient grounds. I had always assumed that my charging issue and slow cranking were due to insufficient positive cable size.
I'm suspecting that the grounding issue is also why my heater hoses don't last but a year before leaking. They seep in a uniform pattern every few inches like the steel webbing is deteriorating. Maybe the cooling system has been acting as a partial ground as well.
