lower radiator hose
Old 06-02-2014, 01:40 PM
tom70's Avatar
Default lower radiator hose
installing a 6.0 in a 1976 camaro. which lower rad hose can I use?
Old 06-09-2014, 12:11 AM
sawzall wielding director
G-Body's Avatar
The truck hose should fit with a little trimming, but will probably rub the frame. I did that on my el camino for the last 120k miles and never had an issue. If you have to buy a new hose anyway you might want to try a Gates 20734, it is supposed to fit the G-Bodies very well and I Assume the 2nd gen would need a similar shaped hose.
Old 06-09-2014, 09:14 PM
gMAG's Avatar
You can also shape a piece of clothes hanger in the form of the intended hose, and go down to Pep Boys. If you ask nicely, an employee will let you behind the counter to compare against their inventory.
Quick Reply: lower radiator hose
