A body guys
A body guys
OK guys, I need some hints on a lower rad hose. Have you found anything close to fitting? I spent an hour staring at hoses hanging on the wall and nothing was close
Depends on which radiator and water pump you go with. I used a truck lower hose. Pretty much worked as OE. I have an LQ4 and Northern LS swap radiator. Post up a picture.
Well I was unable to find anything that would fall into place so I have 2 hoses to make 1. The t stat housing neck size and my rad neck are different sizes so I just need to find a reducer coupling.
Dido. Stock Chevelle radiator with truck pump. But, i'm using an LS3 thermostat housing which angles the neck down a little for better fitup of the truck lower hose. I made a 1/8 spacer with gasket as the LS3 thermostat is taller.
