Gto ls2 in '86 Monte carlo ss
Old 04-22-2017, 11:12 PM
  #141
truckdoug's Avatar
hey you're pretty good at rowing that t56!
Old 04-22-2017, 11:29 PM
  #142
onebadbowtie86's Avatar
Thanks Doug, Made 12 passes and never missed 3rd!
Old 04-23-2017, 02:17 PM
  #143
Another run:
https://www.youtube.com/watch?v=RukS...ature=youtu.be
Old 04-23-2017, 03:01 PM
  #144
truckdoug's Avatar
what was the sixty on that one? looks like you put a lot more burnout heat into the tires....did it help?
Old 04-23-2017, 03:49 PM
  #145
That was a 1.8 60'. I didn't get either of my 7.50 runs with 1.75 60' on film. The heat helped. I ended up airing the tires back up from 12 psi to 17 and I was cutting better 60'. I ran out of time but wanted to bump the launch rpm up to 5-5500 rpm to see if it would help the 60', which I think it would.
Old 04-23-2017, 09:10 PM
  #146
truckdoug's Avatar
yeah i bet you could leave with more rpm. you might end up taking some air back out though.
Old 04-23-2017, 09:33 PM
  #147
For sure, I just need more time at the track to mess with launch rpm/ tire pressure. I want to get the car to 60 foot better. I Might pick up some drag shocks for the next time I go to the track. I need to get the car really working before I worry too much about power adders.
Old 04-24-2017, 04:08 PM
  #148
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Might try slipping the clutch on the launch...
Andrew
Old 04-24-2017, 04:24 PM
  #149
That's a good suggestion, but when I did that it would dead hook it 60' suffered. Next time I give it a go at the track I'm going to raise launch rpm and if it spins bad I'll slip the clutch a little bit.
Old 05-21-2017, 09:28 AM
  #150
sls1025's Avatar
Default Nice MC and Gear Question
First off - beautiful car thanks for sharing.
I curious about your gearing; I read that you planned on changing the rear gear ratio from 3.73 to 4.30's. Did the 4.30 gear render first gear nearly useless where at times you feel you need to start out in second or the 1-2 shift time (RPM) is to quick? What about general drive-ability, what are your RPM's at highway speeds?
I have an 85 MS-SS that I'm in the process of building with an LS3\T56 connect & cruise set up. I'm still trying to figure out what gears I'm going to use. The car will be driven often, to work occasionally, on trips to show's, and once and a while down a 1/4 mile strip. I've played with various gear ratio calculators but want to hear from folks with actual "seat" time.
I'm not trying to turn your build post into a long discussion on gearing just wanted your opinion on how your particular set-up works.
Thank you
Old 05-21-2017, 07:42 PM
  #151
I ran the 3:73 gearing for years with my f body t56, and it works well except I could never use 6th gear. I never drive my car on the freeway, the closest 70 mph road is an hour away from me.
1st gear does not feel too short, the car still will run 45+ mph in first at WOT. At 60 mph, where I do most of my cruising the rpm's are 1700 in 6th gear. 70 mph would be 2000 rpm. I probably should have gone with 4.10's, because with the 275/40r17 (25.6") tires at 7000 rpm in 3rd gear is 96 mph. My car runs 96+ mph in the 1/8 mile, so I just run 27" hoosiers at the track to correct that.
I love the 4.30's and do no regret switching from the 3.73 if that answers your question. If I put a 4l80e in the car in the future, I probably would put the 3.73 back in though.
Heres a good gearing calculator to mess with:
http://fitbodyshop.net/gear/index.php
Old 05-21-2017, 07:44 PM
  #152
In that video, you can see first isnt too short, atleast I dont think so.
Old 05-22-2017, 04:32 AM
  #153
sls1025's Avatar
Thank you and again - the car looks and sounds great.
Quick Reply: Gto ls2 in '86 Monte carlo ss
