1/4" sounds pretty close even with a heat wrap. Any reason you couldn't just man-handle the brake line and rebend it a little further away? You probably wouldn't even have to disconnect and re-bleed the system.
Move it !... even with wrap.. I would think that it would still transmit the heat over a short time being that close... better to be on the safe side being this is your brake system....
