Hot side for G-body?
Old Nov 17, 2014 | 04:31 PM
Streetracer09's Avatar
Default Hot side for G-body?
Do any of you guys know of a turn key Hot side that will fit into a G-body without alterations?
I'm looking at the CXracing Kit on Ebay. It's made for an F-body but I feel like it should work because we have more room. I'm not running any AC or anything.
http://www.ebay.com/itm/380760503742?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'm mainly concerned with the Headers and crossover with the T4 flange. After I get as far as I can I'm gonna drop it off to my chassis guy for cage install and finish up the cold side and down pipe.
Old Nov 17, 2014 | 11:13 PM
1970camaroRS's Avatar
Probably not because of the steering setup on g-bodies.
Old Nov 18, 2014 | 09:49 AM
bigmandengo's Avatar
As far as I know, there is no bolt in, off the shelf hot side setup for g-bodies.
The easiest option I have seen so far is to have someone like kbracing build you a log manifold and then you build the crossover and downpipe. Check out the t-type that denmah just posted over in the forced induction section. Simple turbo/hot side setup.
Old Nov 18, 2014 | 04:07 PM
WSLN 6's Avatar
I may go that exact direction, T4 7675 Precision, Powerstroke intercooler.
